Need help migrating EVERYTHING from one copy of windows 10 to another on the same ssd
Ive been using an illegitimate copy of windows 10 now for quite some time and its showing that annoying activate your windows text on the bottom left. So i decided to buy finally a copy of windows 10 but i wanted all my installed programs, files, and if possible settings from the illegitimate copy to the legit one.
Thanks for taking the time to read and helping
https://linustechtips.com/topic/821251-need-help-migrating-files-from-same-os/
if you have bought a windows 10 product key, you can activate it with your current system (no reinstall needed, assuming you have the same edition of Windows 10 as the key you have)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
1 hour ago, SHOOK_Linus said:
You could make a disc image or a backup with windows and then apply the backup to the other computer, it requires having a disc copy of windows (or maybe a USB copy would work too, idk)
Ill try that out later. Sounds like a good solution
For some reason the illegitimate copy doesnt let me do that. I dont know why
