Long term build plan
Go to solution Solved by LienusLateTips,
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£178.95 @ Aria PC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (£84.47 @ Ebuyer)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory  (£147.99 @ Ebuyer)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  (£76.92 @ Ebuyer)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC)
Video Card: Asus - Radeon RX 560 4GB STRIX Video Card  (£125.50 @ Amazon UK)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case
Power Supply: *Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£82.98 @ Ebuyer)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  (£82.20 @ Aria PC)
Total: £817.00
Generated by PCPartPicker 2017-08-12 19:50 BST+0100
Hey guys, my pc is currently around 2/3 years old and it's complete garbage right now so I want to upgrade to a amd ryzen 5 1600, this is the pcpartpicker link https://uk.pcpartpicker.com/list/CVWbM8 you can recommend me alternatives. (I want a rgb build and I probably won't upgrade until years) (Trying to make it as cheap as possible)
https://linustechtips.com/topic/821081-long-term-build-plan/
current specs?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290113
Just now, Droidbot said:
That's a M.2 SATA drive though, not M.2 NVMe.
In addition, Green is a rebrand of SSD Plus
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290117
1 minute ago, Moeplazz said:
Current specs on my profile, the pc is too shit so I don't even keep track
which corsair 550w
some are good some are bad
might be able to reuse
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290149
Just now, Moeplazz said:
I'm selling my current pc so I'll buy a new one anyway and it's not even semi/fully modular..
oh ok
what are you trying to do with this build
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290161
Just now, JDE said:
oh ok
Stream and play games like overwatch, csgo, rainbow six siege, minecraft (usually lags for me and I get a lot of fps lags)
And for some reason the steam browser keeps crashing.. idk if that happens to anyone else. I was banned in csgo yesterday 2 times because it kept crashing and it won't let me reconnect
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290170
Total: £817.00
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290180
Total: £817.00
Thanks for helping, have a nice day. :D
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290199
Total: £817.00
Did you post that just to replace the SSD?
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290206
yeah :P
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/821081-long-term-build-plan/#findComment-10290318
