I believe they're the same, but you'll need to check which CPU's are compatible with your motherboard before dropping the new chip in.
SFF-ish:  Ryzen 5 1600X, Asrock AB350M Pro4, 16GB Corsair LPX 3200, Sapphire R9 Fury Nitro -75mV, 512gb Plextor Nvme m.2, 512gb Sandisk SATA m.2, Cryorig H7, stuffed into an Inwin 301 with rgb front panel mod.  LG27UD58.
Aging Workhorse:  Phenom II X6 1090T Black (4GHz #Yolo), 16GB Corsair XMS 1333, RX 470 Red Devil 4gb (Sold for $330 to Cryptominers), HD6850 1gb, Hilariously overkill Asus Crosshair V, 240gb Sandisk SSD Plus, 4TB's worth of mechanical drives, and a bunch of water/glycol.  Coming soon:  Bykski CPU block, whatever cheap Polaris 10 GPU I can get once miners start unloading them.
MintyFreshMedia:  Thinkserver TS130 with i3-3220, 4gb ecc ram, 120GB Toshiba/OCZ SSD booting Linux Mint XFCE, 2TB Hitachi Ultrastar.  In Progress:  3D printed drive mounts, 4 2TB ultrastars in RAID 5.
https://linustechtips.com/topic/820717-cpu-swapout/#findComment-10286002
1 hour ago, CUDA_Cores said:
It depends, what CPU and mobo specifically?
Some LGA775 mobos will only cooperate with the core 2 duo and core 2 quad series processors while some will only work with the netburst architecture (pentium 4, pentium D). Others will work with all of them. What CPU and mobo are you intending to use?
Some mobo straight out of an office PC. Ill just trial-and-error it
https://linustechtips.com/topic/820717-cpu-swapout/#findComment-10286678
