Hi guys,
My computer isn't receiving any power at all. I tried plugging just the psu into the motherboard via the power cable and the cpu power cable. I'm getting no lights, no fan, nothing. I brought it to a repair shop and they said the only non-functioning piece is the motherboard. But upon buying a new motherboard and trying a build with that and once again getting no power I can't see that being the problem (unless this motherboard was faulty from the get-go).
Can anyone think of why I wouldn't be getting any power? The wall socket works, and I've tried with 2 different PSU's and motherboards. Could a faulty CPU be preventing me from turning on the mobo?
https://linustechtips.com/topic/820305-no-power-at-all/
If this is your first build. Make sure all the cpu cables are plugged in. For some cpu's it required two plugs. If that dosent fix it, since you are getting no power, make sure ur psu cables are all properly plugged in, also it could be that your psu is turned off xD.
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280767
Just now, McRazzle said:
It is my first build, however I have had it up and running for over a month, and then I shut it down and it would never turn back on again. The PSU is being switched on, and the cables are firmly in place.
Do you have a amd or intel build.
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280789
intel. specs:
i5-7600k
MSI z270 tomahawk arctic
Corsair RM650X psu
Corsair Vengeance RAM (8GB)
Hyper 212 evo cooler
But I am only plugging in the psu, mobo, cooler, and I have the cpu in as well.
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280804
Did you press the power button on the back of the PSU?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280816
Make sure your 24pin is plugged in all the way. And all your fan cabels are in properly. What I would also do, is take off your cpu cooler, turn on your pc and see if the cpu actually heats up. If the cpu heats up that means that your psu is functioning properly. if it dosent heat up, than either your mobo is fried or ur psu is fried,
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280830
yeah don't do that
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280836
3 minutes ago, McRazzle said:
If the PSU is working but the mobo is faulty would the psu fan still turn on?
If the mobo isnt working then the psu fan wouldnt even turn on because of the power button on your case. Also make sure your case cables are properly plugged in.
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280871
I have taken it out of the case because I want to test it with as few parts as possible. Just the cpu, mobo, cooler, and the psu. It didnt work in case and its not working out of case
https://linustechtips.com/topic/820305-no-power-at-all/#findComment-10280897
