Running a 1700x in my new build theme is yellow and white im going to paint the outer rim of the fans yellow and have white fins if i go with this cooler my ? is Phanteks PH-TC14PE 140mm that going to cool my 1700x great and it dose not support am4 but my local micro center is selling stand alone am4 brackets would i be able to just pick one of those up and be set?
https://linustechtips.com/topic/819992-1700x-cooling/
so basically you're asking if the Phanteks PH-TC14PE is good enough to cool a 1700x? if yes the answer is yes it will be good enough.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/819992-1700x-cooling/#findComment-10282496
As for bracket, your best bet is to contact Phanteks support and ask them. Usually you can even get bracket for free if you provide receipts for both cooler and CPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/819992-1700x-cooling/#findComment-10283723
