Hey all, So I'm having an issue with my steam installation detecting my mic...
It started with people telling me "your mic just sounds like wind". I tried voice loopback and setting my mixer volume to 100%... Nothing.
I've tried the steam audio test and it detects that my mic is plugged in but there is no output, I uninstalled all my realtek drivers and got new ones from the official website, still no luck. I've disabled all other devices, no luck, I've unchecked "exclusive control", I've disabled share in Geforce Experience, I've physically messed with the FPAudio connector on the motherboard to make sure it's fitted securely.
What makes this whole issue so infuriating is that EVERY OTHER app and even windows itself can detect output from the mic, Discord works perfectly, so does the "Listen to this device" option...
Please help...
Dylan.
https://linustechtips.com/topic/819815-steam-not-detecting-microphone/
I assume your microphone is set to default device right?
Current Build
Successful Builds
Just now, Dylanc431 said:
Yes, that is correct.
what microphone btw>?
Current Build
Successful Builds
It's a Turtle Beach EarForce XO Four, connected to 3.5 mm connector on the front panel
have you tried plugging it into the back?
Current Build
Successful Builds
Yeah, still the same issue
what IS steam detecting for voice?
Current Build
Successful Builds
1 minute ago, Dylanc431 said:
No, steam tells me that the device is plugged in, but when I hit test microphone I get no signal at all
try changing it to a diffrent device then back
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
even when you tap the microphone to test it?
Current Build
Successful Builds
1 minute ago, MkaiL said:
That's an xbox headset where mic and audio goes through the same 3,5mm jack but pc's usually have audio and mic separated so you'll need an adapter for it to work on pc.
I should've known :/
Current Build
Successful Builds
  • 3 weeks later...
Something like this (and plug it in the back)
  Reveal hidden contents
I'm still having the issue but some personal business got in the way of me replying, I do already have an adapter that splits one 3.5mm port into 2 3.5mm jacks for the audio, otherwise I wouldnt be able to use discord and stuff, I thought that'd be fairly obvious from my original post.
