Problem with my internet
Solved by Stevers108,
3 minutes ago, Keanen said:But the signal here is not that good
You can purchase a device that plugs into an outlet in your room (which has an Ethernet port on it), while the second devices plugs into an outlet near the router (You then plug an Ethernet cord from the device into the router). It's a bit hard to explain. I'll look one up for you.
Found it
