I'm a highschool student, and I'm going to start college in a year or so. I have an average build (FX-6300, 8GB RAM, R7 265) that uses a Micro ATX form factor, but it's in a quite large ATX case. This large ATX case isn't going to be the best in the dorm room.
My question is, should I buy a small Micro ATX case like the Apevia X-QPACK3 (which is 15.2 x 10.2 x 13.8 inches), or should I opt for a Mini ITX case? Getting a Mini ITX case will mean that I will have to upgrade my whole system, because I'm not currently using a Mini ITX mobo, and because the AM3+ platform doesn't even have Mini ITX mobos. Upgrading would be cool (Ryzen anyone?), but I do want to save money. Do you think I will be able to get by with a Micro ATX case (like the one mentioned before) in the dorm room, or should I upgrade to Mini ITX?
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/
I'd say it should depend on whether you plan to run any other pcie card than a graphics card. It's generally only has a single pie slot.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10270752
Really depends on your dorm. Most dorms I've seen have desk space and enough for even a mid tower case under the desk. However if you are really cramped for space a mini ITX would be ideal if it needed to be on the desk with you. ITX is really nice if you go to lan parties as well. Check out some of LTT's reviews of ITX Cases, and see if you need a case that small to fit in your room, other I think micro ATX should be fine.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10270756
Get the Apevia since it'll be easier to upgrade to.  If you do want to upgrade, go for a Mini ITX i5 or i7 build since Ryzen doesn't really have ITX boards.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10270757
If you're trying to maximize space, consider getting the Silverstone FT03. It's got a smaller desk footprint, but is still mATX.
They're a little on the pricey side though.
ITX is nice but generally needs a little more planning. You can get some disgustingly small cases though, like the Firewolfy MI6; you can fit 2 side by side on a sheet of paper.
There's enough though. 5 =/= 0.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10270879
I'm only going to be running a graphics card - but that's not the point here, the point is the size of the case.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10272912
Hmm... Do you know of any Micro ATX cases smaller than the Apevia X-QPACK3 I mentioned?
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10272913
Well, that rules out Mini ITX since if I upgrade I want to get Ryzen. Do you know of any Micro ATX cases smaller than the Apevia I mentioned?
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10272914
11 hours ago, hi mate said:
the best way to make it smaller is a small cube case, or even a home theatre case if your GPU will fit
Do you know of any Micro ATX cube cases smaller than the Apevia X-QPACK3 I mentioned? I don't think a home theatre case will work since my GPU isn't low profile.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10272915
Ooh, those are cool, but pricey. Do you know of any mATX options that are in between the Silverstone and the Apevia in terms of space?
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10272925
There are mITX Ryzen boards, if you wanted to go that route.
21 minutes ago, no one in particular said:
The Silverstone TJ08B-E looks like a good option, what do you guys think?
Not bad. You could also consider:
  • Corsair Air 240
  • Thermaltake Core V21
  • Aerocool DS
  • Phanteks Enthoo Evolv
  • Jonsbo C2 (if you don't mind using an ITX video card)
  • Thermaltake Urban SD1
  • Fractal Design Define Mini C
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10273119
  • Corsair Air 240
  • Aerocool DS
Those all look reasonably good - I keep coming back to the Silverstone FT03 though because of its tiny desk footprint. Are there any other cases similar to that in desk footprint?
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10273141
It's the only case I've seen like that.
You can get the mITX version quite cheap, however it would require a new system and a short video card.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10273144
I might just save up for the more expensive version. We'll see.
I'd look at it more as an investment than anything. A nice case can last many, many builds.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10273155
Yeah, just trying to decide if it is worth it. I've already got a Corsair SPEC-02, which is fine for my current needs, it's just a little big.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10273785
17 minutes ago, no one in particular said:
I'm also wondering how well my non-modular power supply is going to do in that case.
Non-modular psu are typically easier to use in sff cases. Same length modular units need at least an one additional cm for cable connections.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10273926
It should, I think there'd be a lot of internal space where the 3.5" drive goes.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10275238
That's true - I didn't think about that. I'm just wondering where to put all of the extra cables.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10275393
Looking at the case, that hot-swap bay looks pretty interesting, so I might use that for the 3.5 inch drive to save space in other areas of the case.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10275397
Or move it to an external enclosure if it's just for mass storage. I haven't had an HDD actually living in my system for years.
https://linustechtips.com/topic/819446-micro-atx-or-mini-itx/#findComment-10276626
