Hi guys~
Currently researching into building a discrete wall mounted gaming PC. My intention is to increase desk space and to make the PC more accessible.
I'm thinking of using TV mounts for the project.
The goal is something discrete for general gaming and the like~ nothing fancy or flashy~
My current setup:
i7 2600k (Close looped cooler)
P8Z77-I Deluxe
16GB DDR3
CM HAD Stacker 915F Case
GTX 970 Asus
XFX 650W Full Modular PSU
BenQ 144hz monitor
Random 24" monitor in Portrait
Materials: Thinking about MDF and Carbon Fiber sheeting for a clean look.
I've added a reference image of a wall mountable PC. I will probably skip on the LED lighting.
Ichi~
https://linustechtips.com/topic/818959-discrete-wall-mounted-pc/
I'm busy with a wall/wall box build and you can just have two fans, don't need four. as long as the air is moving through the system you good. another easy way to do it is mount it to the bottom of the desk like linus did and than put a protector over it if you worried about your knee's.
Enjoy though, I love Wall PC's. play around in sketchup to get some ideas of what you want.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
9 minutes ago, Himommies said:
Why not get a Evolv Shift.It has a very small footprint,otherwise the closest option is Thermaltakes P-Series
My CM Stacker 915F is already about the same footprint as the Thermaltakes P-Series.
I need more desk space and I ruse to leave my PC on the floor...
Edit: Plus, I like the idea of an wall mounted PC with good cable management
Get a Evolv Shift.It's footprint is small as hell and it's pretty
My life
$1,000 CAD for a PC case is too steep
My entire rig is worth afraction of that at 2nd hand market prices...
The next best option is to get something like the NCASE M-1 or DIY somethig
My life
putting the gpu parallel to the pcie slot may make it easyer to run a pcie riser cable
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
Just now, seon123 said:
How about the Thermaltake Core P3? I think it's wall mountable
Yes... I have thought about using existing cases. The P3 was among the top 3 of my list.
However, I'm still considering using a sheet of MDF and TV wall mount for this project.
And some carbon fiber sheeting on the MDF for a clean and slick look.
Then I wish you the best of luck. Hope you share it
3 minutes ago, mok said:
nothing discrete about wall mounting a pc lol
Unless you're Linus and make a fully wall integrated PC AKA Wallputer~
And all you see is connectors coming out from the wall ?
Edit: Yes, it will run Minesweeper and Minecreaft at 30 FPS
