Problems cloning hard drives
Go to solution Solved by Kingslayer Kyle,
SOLVED:
I used this, it worked pretty much straight away
https://www.tenforums.com/software-apps/27180-windows-10-recovery-tools-bootable-rescue-disk.html
Sup guys, currently experiencing some issues whilst cloning from a smaller to a larger hard drive (operating system)
For some reason it won't boot, Up to yet I have tried Acronis True Image and Macrium Reflect,
I chose the source disk (my old windows drive) and the destination drive (the new hard drive that I wanted to clone to)
When trying to boot up the new drive is just acts as if windows isn't installed...
Any ideas?
Thanks in advance for any help
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
https://linustechtips.com/topic/818755-problems-cloning-hard-drives/
Sounds like you're missing a bootloader. Why not reinstall Windows?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
4 minutes ago, NumLock21 said:
Try again by deleting everything from your new HDD including all the partitions. Make sure the program is up to date.
Every time I have cloned the drive the destination drive has been completely wiped (Including partitions) and they are up to date.
There's too many programs/settings that I really don't want to have to set up from scratch again
SOLVED:
It's a possibility your drive is GPT and the program you're using is not supporting it, so it skips the bootloader.
Yeah that's what I thought, I think the boot disk that I used was able to fix that issue though
