Hi I posted here not too long ago about a 1050ti not giving a display output on my system. When installed in my system I do not get any signal on my monitor but the monitor detects that the cable is plugged in. I have tried updating the bios, using a different pcie slot and power supply and uninstalling graphics drivers but nothing has worked. The system boots up without a problem with the old GPU (gts 250) in it and the gpu itself is not dead because I took it back to the shop on it worked fine on their test system. I then purchased a xfx r9 280x in the hope that it might work in my system but so far I have the same issues. Does anyone know what the issue is and are there any beta bioses for my motherboard that I can try.
System specs:
  • CPU
    Intel Core i5 760
  • Motherboard
    Gigabyte P55A-UD3
  • RAM
    Hyper X Fury (2x4gb) 8gb 1866mhz DDR3
  • GPU
    gtx 1050ti
  • Case
    Cooler Master CM 690 III
  • Storage
    Wd Blue 1tb
  • PSU
    Siverstone Strider Plus 500w
  • Display(s)
    Benq G2000W 1680x1050
  • Cooling
    Cooler Master Hyper 212 Evo
Quote or tag me @Lemtea so I can see your reply.
DAYBREAK: R5 5700X3D | RX 9070XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | WIN 10
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
https://linustechtips.com/topic/818679-still-having-problems-with-gpus/
