Out of all my knowledge in electronics i would say that networking is my worst when it comes to understanding. So I have a few questions for you guys.
1. Can I just buy a better router to improve my internet upload/download speed?
If question 1 is no, what do i need to increase my internet speed? (besides changing my ISP)
2. If I hook up two PCs via Ethernet, would i be able to transfer files between them?
3. What are the properties in a router to look for when determining whether or not it is good?
Thanks, and sorry for my lack of knowledge, I find this very confusing for some reason.
https://linustechtips.com/topic/818569-noob-networking-questions/
1
Nope. Unless your router only supports 802.11b/g/n or b/g you will not see a difference in speed over a wireless connection. Most routers released in the past four years come with AC support already. As for a wired connection, there is absolutely nothing you can do. You will have to contact your ISP to learn about their upgrade plans.
A lot of routers can be used to create a network drive via the USB port. Connect a drive to the port, install the needed software for the router (EX: Netgear Genie), and you'll be able to upload files to the drive and pull them on the other computer. Alternatively, see this article to learn how to create a shared network drive.
802.11b/g/n/ac support, as mentioned above, is necessary to deliver the best speeds over a 5GHz band to a wireless-connected device. The rest is reliant on range capabilities of these routers.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
1. If your current router is failing to provide the speeds that you already pay for then it might help, but it is very unlikely. There is no way to increase speed past what you pay for, without paying for more.
2. Yes.
3. What do you plan on doing with it? Do you need wireless? Do you need a built in modem? Do you need to connect more than 1 ethernet device?
Read reviews, find a budget and buy the one with the most features you want that has good reviews and ask people on the forums opinions on a router and they'll be sure to help you out
