select both wifi and ethernet adapters > right click > bridge connections
Connect your AP to the ethernet port and you are done.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
11 hours ago, Ethocreeper said:
@Lurick can you help?
am asking you because i know your job is networking :)
So you're looking to connect the desktop, which isn't getting wireless, to an access point and then share that with the laptop?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Did that internet just stoped working on the laptop
Will try again tho just to be sure
No the laptop gets wireless and I want to share it with my ap through the Ethernet port
you have to do it with the wifi connected but the ethernet cable disconnected(otherwise it will share the ethernet to your wifi). Your new bridge should show the same name as your SSID. If it says something like "limited connectivity" or "ip conflict" , right click and select "fix issues"
Aaa did that with the cable connected
Will try it later and update you
the laptop internet works and it says its correctly bridged wifi adapter to Ethernet but devices connected to the ap cannot connect to the internet
Did you have a previous configuration in your AP? You might need to manually configure your AP. Depending on your device, some AP have a default IP so you can access the configuration portal.
If your AP has dhcp enabled by default, you have to make sure it is getting a valid IP.
TLDR: read the user manual for the AP, make sure DHCP is enabled and try again.
