Having issues with memory usage
Regardless of usage I am hovering around 95% (+/- 3%) total memory used, I have attached a screen shot to show the processes running
Have recently replaced what i thought was faulty ram but no luck there, so still running into this issue with brand new ram
Have run memory diagnostic test and no errors came back although something is clearly not running properly
Usage stays the same regardless of processes, i.e hovers around 95% be it playing games or just idling
Hard drives / SSD have ample space on each so no full drive issues
Really stuck on fixing this so any help would be greatly appreciated
https://linustechtips.com/topic/818230-memory-usage-issue/
Not exactly sure what it means, but the amount of memory in your non-paged pool seems quite large. Here is some information on paged pools vs non-paged pools: https://msdn.microsoft.com/en-us/library/windows/desktop/aa965226(v=vs.85).aspx
I think your issue has something to do with how Windows is managing your memory. Try increasing, decreasing, or disabling your page file.
https://linustechtips.com/topic/818230-memory-usage-issue/#findComment-10257758
