Posted August 6, 2017 Which one you think is better or which you gonna choose ? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2017 43 minutes ago, firstpon said: Which one you think is better or which you gonna choose ? HD120 for cool lighting effects, as you can make custom controllers for them. Then the sp120 rgb, then non led variant. But really we need more info about placement etc, as airflow vs static pressure really depends on case and cooling setup. At similar RPM, my static pressure fans pull more air through a filter and rad than my airflow fans can push through a dust filter, and the converse is true in unrestricted performance for the rear exhaust fan. Sync RGB fans with motherboard RGB header. Main rig: Ryzen 7 1700x (4.05GHz) EVGA GTX 1070 FTW ACX 3.0 16GB G. Skill Flare X 3466MHz CL14 Crosshair VI Hero EK Supremacy Evo EVGA SuperNova 850 G2 Intel 540s 240GB, Intel 520 240GB + WD Black 500GB Corsair Crystal Series 460x Asus Strix Soar Laptop: Dell E6430s i7-3520M + On board GPU 16GB 1600MHz DDR3. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
