1 minute ago, charrst said:
Just so you know, you could have just linked straight to pcpartpicker instead of going through the trouble of taking a screen capture and uploading it to a file hosting service.
Also, I'll go ahead and ask these because someone inevitably will: What do you plan on using this build for? What is your budget?
Thanks for the suggestion! I plan on playing CS:GO, PUBG, Rust, RL, and lots of other games. I do hope to keep the build's budget modest.
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255706
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.88 @ OutletPC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($83.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Storage: PNY - CS1311 120GB 2.5" Solid State Drive  ($52.99 @ Best Buy)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB Mini Video Card  ($259.99 @ Newegg)
Monitor: Lenovo - L24q 23.8" 2560x1440 60Hz Monitor  ($179.99 @ Amazon)
Total: $899.82
Generated by PCPartPicker 2017-08-05 18:53 EDT-0400
100$ above the original build but comes with a new monitor for some 1440p gaming, your current monitor can be used as a second monitor I guess.
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255723
Total: $899.82
I know that there has been a lot of talk of this new CPU for AMD, but I want to know how good is it? I have looked at some videos and looked at some results but what is your honest opinion? I can get the i5 7600k for the same price as the Ryzen but I would pay more for the mobo.
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255735
More cores, SMT, benefits in workloads and multi-core tasks, has amazing IPC to benefit in gaming, and with games utilizing more cores that lead on Intel will only get more significant.
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255740
Get Ryzen 5. i5 CPUs aren't worth it anymore...
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255741
A 1600 has triple the threads - most modern games use at least 4 and often 6-8 threads easy.  Modern i5's are a very poor choice.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255782
51 minutes ago, Azriel said:
What would you suggest in terms of a mobo if I get the 1600x?
Get a 1600 non X and use the stock cooler. Then get whatever b350 or x370 mobo you like
https://linustechtips.com/topic/817995-replacement-build/#findComment-10255907
When looking at the rating of most motherboards, they barely get over 3/5 stars. Would you mind listing some motherboards that are of good quality?
Check out the asrock AB350(M) is good.  Comes in matx and atx options.
19 minutes ago, Azriel said:
Also if I may ask why should I avoid MSI? Their ratings for the AMD boards are quite good.
Msi mobos tend not to last.
https://linustechtips.com/topic/817995-replacement-build/#findComment-10256223
