So I was putting together my parts list for my first PC and I was hearing stuff about fan splitters and PCIEs cables or something like that. Can someone explain what they are and waht they're used for please. Any help would be appreciated :)
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
https://linustechtips.com/topic/817643-fan-splitters/
Fan splitters are used to take one of your motherboard's fan headers to power two fans. You typically will use this if you have more fans in your case than your motherboard has fan headers, or you just want better cable management. As for PCIe cables, these are connectors from your power supply that provide power to PCIe components such as graphics cards.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10252567
Ok thanks, also how do I know how many fan headers my motherboard has? This is the motherboard I'll be using: Asus ROG Maximus IX Hero
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10253764
It's got at least 8 4-pin PWM fan headers, plus an extra 3 through an extension module provided with the board.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10253783
Oh ok, are all fans 4-pin?
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10255933
In general and specifically for Asus go to the motherboard web page, Specification tab, https://www.asus.com/us/Motherboards/ROG-MAXIMUS-IX-HERO/specifications/. For Asus motherboards, go to the Internal I/O Ports section. Go through the list.
The Maximus IX Hero has two cpu fan headers, 3 chassis fan headers, (an AIO pump header, a water pump header), and a high amperage fan header, all 4-pin. In addition there is a 5-pin header for an add-on Asus fan extension card - https://www.asus.com/Motherboard-Accessory/FAN-EXTENSION-CARD/.
This and more information can also be found in the User Manual.
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10256333
Thanks so much, that was a lot of help but if I have 4 maybe 5 silent fans and 2 high static pressure fans for the radiator, so I would need to use a fan splitter, and also what's a cpu fan header and can I use cpu fan header or chassis fan header for everthing fans. I know I'm asking a lot but you really helped so far :D
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10258006
If you are using an AIO cpu cooler the radiator fans typically plug into the pump (which is usually part of the cpu block). You have a lot of options for controlling fans. Without knowing the model of cpu cooler it's tough to suggest a fan layout. But I suspect the motherboard has more than enough fan headers for your needs.
If more fan headers are needed you might try finding an Asus fan extension card. The card supports 3 additional fans and 3 additional thermal sensors. Unfortunately it is not an easy part to locate.
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10259811
Ok thanks, helps a lot and btw my pump is the EK-XTOP Revo D5 PWM - Plexi (incl. sleeved pump) Incase you know what I can do
Retrowave
Set Up
  • Audio
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10261972
At a guess the unit's PWM connector would use the Water pump header. The radiator fans could then use the cpu fan headers. But I would suggest that you ask the question in the Liquid and Exotic Cooling section.
https://linustechtips.com/topic/817643-fan-splitters/#findComment-10262031
