I have a male to male fitting stuck and overtightened on a 240mm radiator. Haven't tried wd40 but it hasn't worked in the past on other overtightened and stuck wc components of mine. My last resort is that I am going to buy an angle grinder from harbor freight and cut in half part of the top and hopefully it will be easier to take the fitting off so I can dispose of it and reuse my radiator.
Rig Specs:
Ryzen 7 1700 3.9ghz @1.33125v Cinebench Scores Best:1750cb Average: 1735cb
Asrock X370 SLI/AC  SOLD
Evga GTX 560 Ti 1gb    Just got a EVGA GTX 780 HydroCopper
G.Skill Ripjaws V 2x8gb 2400mhz oc’d to 2666mhz (bought when ram was still cheap :()
Corsair RM850
Enthoo Pro M Acrylic Changing to a Inwin 301 soon
Custom CPU Loop (watercooling is boring to me right now so I want to go back to air cooling and do like one more WC Loop in a Inwin 301)
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Not So Shitbox v3 Specs:
I7 2600k oc'd to 4.7 @ 1.4ish (will do more when I get a better cooler)
MSI P67-GD55  Sold to fund my gpu
Gigabyte Windforce HD 6950
Team Elite Plus 8gb DDR3 (1 stick) @ 1600mhz
Thermaltake Toughpower 750 watt
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
15in IPS 1080p display
https://linustechtips.com/topic/817596-fitting-stuck-on-radiator/
20 minutes ago, Gungpae said:
have you tried pliers?
Yeah I've tried pliers to no avail.
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
14 minutes ago, Colin Donoghue said:
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
Same thing happened to me, M-M fitting that was stuck on reservoir which stripped the threads. Just put some masking tape on it and use pliers. Wouldn't work from first try, but if you try really hard you can get it out. Also, make sure the threads on the rad aren't stripped. I used teflon tape on my stripped reservoir and it works great, however it was on plugs and not fittings so I'm not sure how it would work for you.
Good luck.
It's hard for me to see in the photo, but if your fitting has little divots (Two at the top, two at the bottom) like this one. On the actual fitting, not the ring:  12-bc2.jpg?format=750w
You can just stick like a knife (or Popsicle stick/something skinny) and turn. You get a ton of torque and it doesn't slip. In fact, I feel like XSPC included the divots just for that reason.
The picture sorta looks like you don't have them though :(. I know your fitting is male to male btw and the one above is compression, but it doesn't hurt to look.
Hey guys, sadly some of the methods like wd 40 did not work so I ended up using it in my build as a way to connect my 5 way adapter to my drain valve and other fittings. Thank you all for the suggestions.;
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
