I just got all of my parts for my new X99 setup, but I'm running into some issues. The initial boot when good, but it froze two screens into trying to install windows. I rebooted and same deal. Tried one last time and that is when the boot looping started. I have already tried moving both of my ram sticks around to different dimms to no avail. Power supply, GPU, and RAM were all verified working on my old rig. The motherboard was picked up from microcenter on open box claiming to be verified working.
Specs:
CPU: I7-6850K
MOTHERBOARD: MSI X99A GAMING PRO CARBON
GPU: EVGA GTX 980TI SC+
RAM: CORSAIR VENGEANCE DDR4 3000MHZ
PSU: CORSAIR HX1000i
STORAGE: SAMSUNG M.2 960EVO 500GB
Have already done the following things:
-Cleared CMOS
-Reseated Cables
-played with different dimms for ram
Any help is much appeciated
https://linustechtips.com/topic/817364-boot-loop-help/
that does sound an awfull lot like a faulty motherboard. it could also be the drive that you are installing on, try if you can change the boot order and format the drive, or take it out and use another drive.
if you have several RAM sticks, try it with just one, maybe one of the sticks is broken. and take out the GPU and use the IGPU. basically try to use as few components as possible so you can exclude everything else.
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249551
Update the BIOS. If it's an older board, it may not be up to date. AFAIK, X99 was really buggy at release, more so than Ryzen.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249558
Just now, IT_Techie said:
Just to add, the boot loop is occuring within the first 5 secs on booting, and in that time it does not post.
Can you get to the BIOS?
Mouse: EVGA X17
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249573
I was afraid of this, if this keeps happening even whit all unnecessary things disconnected then you can't really do anything.
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249578
I cannot
RMA the mobo.
Mouse: EVGA X17
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249581
1 minute ago, IT_Techie said:
Is there any chance it is the CPU?
Not really. Is it used?
Mouse: EVGA X17
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249588
8 minutes ago, IT_Techie said:
It was sealed in box. I just want to be sure since microcenter "claimed" the motherboard was verified working
If the CPU is new, it should be fine. CPUs don't break easily, unless they are physically damaged or overvolted and fried, though they usually shut themselves off. Take the board back to Microcenter and have them fix it, since they said it was working.
Mouse: EVGA X17
https://linustechtips.com/topic/817364-boot-loop-help/#findComment-10249625
