Hi.
I spend quite some time in Visual Studio 2017 with Resharper installed. I have a feeling that VS is not so multi-core optimized.
Does anyone know if VS would work better on 10 or 12 or 16 cores compared to 8 or 6 or 4 cores? I mean not only compiling but IDE itself, including XAML designer and plugins.
7700K still rules in the world of single-threaded performance, even compared to 1800X.
Which cpu is best suited for work in VS? Assuming I already have a fast SSD and RAM?
Thanks!
https://linustechtips.com/topic/817315-a-cpu-for-visual-studio-2017/
I'm going to presume they haven't changed it from 2012 but the more cores is generally better for Visual Studio when it comes to building projects
https://stackoverflow.com/questions/11054410/does-visual-studio-2012-utilize-all-available-cpu-cores
https://msdn.microsoft.com/en-us/library/bb383805.aspx
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
17 minutes ago, tridy said:
Hi.
Thanks!
I use a ryzen 1700x OCed to 4.025GHz with 16gb of 3466MHz DRAM for VS 2013 development. Works great. Takes longer to refresh UI than build most times.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
That's the thing sort of. Building from the command line takes less time than building from IDE just because it needs to refresh lots of things. Add Resharper to it and I get like 10 seconds delay after the build to refresh the things on a 20 projects solution. As a result, I was wondering if VS IDE itself behaves better in case of 4 cores vs 8 cores, for example, keeping in mind that the 4 cores cpu has better single-thread performance.
I have no idea about the 4 vs 8 cores, as I came from a i7 3520m 2 core in my laptop. It ran fine, but nowhere near as well as ryzen does. The last intel desktop processor I owned was a core 2 duo, that really sucked.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
  • 4 months later...
VS benefits from more cores. Either way, in your work environment I am sure you have several tabs, sql server, one or two instances of vs, linqpad, and music. More cores will yield better performance. Do not do 4 cores, you will be wishing you had done 8 in 6 months.
