I had installed a voice changer that I got bored and annoyed of so I decided to uninstall it. After some time, it had somehow screwed up my settings and now it sounds like I'm blowing into the mic. I knew it wasn't the mic itself because I tested my mic and it sounded like my voice was deeper and was robotic like in the settings, I have tried reinstalling my drivers but it doesn't seem to work. Has anybody every experienced this problem? If so, do you know how to fix it? The voice changer I installed was ClownFish Voice Changer
Thanks
https://linustechtips.com/topic/817309-problem-with-my-mic/
Thanks
first what mic
https://linustechtips.com/topic/817309-problem-with-my-mic/#findComment-10249060
