So recently my computer has been messing up randomly, Graphic driver would crash even though i updated it to the newest one, My computer screen just went black and i heard the sound slowly glitch out till i was forced to turn it off manually, And i was getting BSOD but i fixxed that issue by updating the GPU. Anyone have any ideas on what it could possible be? Or any programs i can use to scan sytem files/errors and fix them?
https://linustechtips.com/topic/817285-how-can-i-check-system-errors/
Sounds like your card isn't getting enough power. Do you have a Unplugged card that only requires power from the MoBo?
If you need help on used parts, contact me. I'm an used enthusiast.
Open the spoiler to see some cool stuff!
My old/new tech Collection!
CPUs (11)
Intel Pentium III @ 733Mhz (Oldest of the Bunch)
Intel Pentium 4 @ 2.8Ghz (2002)
Intel Pentium 4 @ 3.0Ghz (2003)
AMD Sempron 64 2800+ @ 1.6Ghz (2004, Aug)
AMD Athlon 64 3500+ @ 2.2Ghz (2004, Jun)
2X Intel Xeon X5355 @ 2.66Ghz (2006, Q4)
Intel Pentium E2140 @ 1.6Ghz (2007, Q2)
Intel Xeon E5630 @ 2.53Ghz (2010, Q1)
Intel Core2 Duo E8400 @ 3Ghz (2008, Q1) (In use, @ 3.61Ghz)
Intel Pentium E6500 @ 2.93Ghz (2008, Q1)
GPUs (6)
Palit GeForce 6800 GS (Should be working, AGP 8X)
Club 3D GTS 450 (Working, PCI-e 16x)
Sapphire Radeon X800GTO (Working, PCI-e 16x)
Nvidia GeForce 4 (Last time worked, AGP 4X)
Nvidia GeForce FX (No idea, AGP 4X)
Gigabyte Radeon HD 7970 OC (Semi-dead, PCI-e 16x)
Ram (1)
No idea of the brand or Socket (Whopping 16 Mb memory)
Cables (1)
CrossFire X Cable
Use event viewer.
Mobo: Z97 MSI Gaming 7 / CPU: i5-4690k@4.5GHz 1.23v / GPU: EVGA GTX 1070 / RAM: 8GB DDR3 1600MHz@CL9 1.5v / PSU: Corsair CX500M / Case: NZXT 410 / Monitor: 1080p IPS Acer R240HY bidx
So the GPU i have is  one i've been using for a year or so, IT broke down so i got it replaced, while it was out i used my sisters card and it worked fine, didnt need 2 8 pins like this one, anyway i can make the GPU use more power or something? https://pcpartpicker.com/list/TNxDBm is my build, I have a sapphire nitro r9 390 GPU
Well, you can try to over volt the card, if you want to try. I can't give any promises of it actually taking effect in any way. it will most likely just increase the temps
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
