I'm looking for a PC build for around $2000 Canadian dollars that includes a full rig along with one monitors (pref 1080) and windows 10 home, don't need a mouse or keyboard. I plan to use this build for gaming mostly while being able to stream. I want this build to last me for a long time.  If possible would like to have a case that is all one colour with a tempered glass side panel as well as a SSD would be nice and hopefully having all the parts look sexy. Thanks!
https://linustechtips.com/topic/817227-2000-canadian-build-help/
Please remove it us Dark Theme users can't see it
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Press TX!
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($266.50 @ shopRBC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($121.00 @ Vuugo)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg Canada)
Storage: SanDisk - Ultra II 480GB 2.5" Solid State Drive  ($188.44 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.95 @ Vuugo)
Video Card: EVGA - GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card  ($589.99 @ Newegg Canada)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($114.99 @ Newegg Canada)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply  ($69.99 @ Newegg Canada)
Operating System: Microsoft - Windows 10 Home Full - USB 32/64-bit  ($131.99 @ PC Canada)
Monitor: Acer - XF240H 24.0" 1920x1080 144Hz Monitor  ($335.91 @ Amazon Canada)
Total: $2028.75
Generated by PCPartPicker 2017-08-04 01:43 EDT-0400
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($269.99 @ Amazon Canada)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($46.75 @ Amazon Canada)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($124.99 @ Newegg Canada)
Memory: *Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg Canada)
Storage: ADATA - Premier Pro SP920 256GB 2.5" Solid State Drive  ($114.99 @ Newegg Canada)
Storage: *Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($84.99 @ Amazon Canada)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  ($549.99 @ Newegg Canada)
Case: Apevia - X-MIRAGE (Black/Blue) ATX Mid Tower Case  ($69.99 @ Newegg Canada)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($104.99 @ Newegg Canada)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($249.99 @ Amazon Canada)
Keyboard: G.Skill - Ripjaws KM570 Wired Gaming Keyboard  ($99.99 @ NCIX)
Mouse: Redragon - Centrophorus M601 Wired Optical Mouse  ($18.99 @ Amazon Canada)
Total: $1885.64
Generated by PCPartPicker 2017-08-04 01:44 EDT-0400
Full Specs
Helios EVO (Main):
Delta - Laptop
Total: $2028.75
I've been out of the market for a while so is the Ryzen 5 from AMD the competition for intel's Kaby Lake processors?  Is Team Vulcan a reliable memory brand?
3 minutes ago, DerpBlood said:
Are you able to see it now?  If not I'm not too sure what you mean by pressing TX.
Yep, it's good now. There's a button labeled TX that makes it easy:
and you just select the text and press Tx, and it will magically make it readable to night theme users.
Full Specs
Helios EVO (Main):
Delta - Laptop
Yeah, it's the current competition. It destroys the i5.
Full Specs
Helios EVO (Main):
Delta - Laptop
Yes, both are correct. The Ryzen 5 1600 is better than the Kaby lkae i5's and Team memory is a new company and is pretty good.
Just now, xXBlackIceXx said:
Bad headset, overpriced case for the budget, overpriced GPU.
Full Specs
Helios EVO (Main):
Delta - Laptop
Total: $1885.64
Without the mouse and keyboard would there be any part of the build you would upgrade?
And is Seagate > Western or is it still preference?
Seagate = Western
Full Specs
Helios EVO (Main):
Delta - Laptop
Just now, RaptorCandy said:
Preference imo. Except for the 3TB version i think that one still has problems.
Nah it was the old version they discontinued in 2015/2016
Full Specs
Helios EVO (Main):
Delta - Laptop
14 hours ago, JDE said:
Seagate = Western
I don't plan on currently overclocking and don't know if I will in the future.  Does this affect the cpu choice?
The HDD won't. But if you want to overclock in the future you should get a CPU with a K at the end (i7 7700K) with a motherboard with a Z at the beginning (Z270). If you go with AMD then most of the Ryzen 7 CPU's are overclockable.
All Ryzen processors are unlocked.
Full Specs
Helios EVO (Main):
Delta - Laptop
16 hours ago, RaptorCandy said:
No.
Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard or Asus - PRIME B350-PLUS ATX AM4 Motherboard.  I saw that some people were having trouble with the Asus motherboard bios and the limited amount of fan headers so I'm not too sure which of these two motherboards I should get.
