I'm assuming you plugged in the hd audio header?
Current Build
Successful Builds
Just now, beeny said:
can confirm i have
is there anything plugged into the rear audio ports?
Current Build
Successful Builds
not right now
is the audio device for your onboard audio set to default?
Current Build
Successful Builds
1 minute ago, beeny said:
no i have a headset that i plug in to the back that is the default because i always have a 7.1 usb headset plugged in
that's probably why your front header isn't working. In order to get audio out through the front i/o, your default device should be set to the onboard mobo audio device
Current Build
Successful Builds
if you mean drivers like the realtek ones then those work when there is stuff plugged in strait to my mobo but the drivers dont pick up any device in the front io when i plug it in
then there's probably something wrong with the the hd audio cable :/
Current Build
Successful Builds
