Urgent help???
evga's precision xoc is pretty good. try it.
My Rig: | CPU: Core i7-8086k @ 4.9 GHz | Motherboard: Asus Rog Strix z370 | CPU Cooler: (some coolermaster one that probably should have been retired several years ago) | Case: Corsair 570x | GPU: EVGA GTX 1080 | RAM: 32GB Corsair Vengeance RGB Pro
https://linustechtips.com/topic/816135-urgent-help/#findComment-10235979
good question. *hey google* (sorry i use nvidia)
https://linustechtips.com/topic/816135-urgent-help/#findComment-10235985
got sapphire's Trixx and Amd overdrive
https://linustechtips.com/topic/816135-urgent-help/#findComment-10236004
could be an issue, how much configuration options do you have in UEFI. is it more basic or is it more gamer oriented.
https://linustechtips.com/topic/816135-urgent-help/#findComment-10236011
Someone else has it idk where and @Abyss Gaming probably won't tell where
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/816135-urgent-help/#findComment-10236040
rip
https://linustechtips.com/topic/816135-urgent-help/#findComment-10236046
