Need Advice
Go to solution Solved by Shura,
5 minutes ago, yloswg678 said:
If you want those exact same parts, then you definitely save money but for $8 more,  you can get this with 3000mhz
PCPartPicker part list: https://pcpartpicker.com/list/bFwTcc
Price breakdown by merchant: https://pcpartpicker.com/list/bFwTcc/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.88 @ OutletPC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Total: $412.86
Generated by PCPartPicker 2017-08-01 01:12 EDT-0400
So I've been looking to upgrade my pc for a while now and don't know what would be the best product for my price point. Currently I have an AMD FX 8320 for my cpu, some motherboard that I don't think is exactly relevant (its a Gigabyte 78LMT) and a GTX 950 from zotac for my graphics card. I'm looking to replace all three, and ive only got ~$500. So if any of you can help me get a decent upgrade for that price I'm all ears.
https://linustechtips.com/topic/815687-need-advice/
Do You have discord? So I could call you and Help you out?
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/815687-need-advice/#findComment-10231306
What country
Keep in mind he maybe doesn't want to talk to people
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/815687-need-advice/#findComment-10231314
Just now, Billy_Mays said:
What country
I know But Im just asking.
https://linustechtips.com/topic/815687-need-advice/#findComment-10231315
Yeah I was letting you know that
https://linustechtips.com/topic/815687-need-advice/#findComment-10231317
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($69.99 @ Amazon)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($82.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB SC GAMING ACX 2.0 Video Card  ($158.88 @ OutletPC)
Total: $509.74
Generated by PCPartPicker 2017-08-01 00:44 EDT-0400
https://linustechtips.com/topic/815687-need-advice/#findComment-10231319
What do you want to do with it
https://linustechtips.com/topic/815687-need-advice/#findComment-10231320
Total: $509.74
Currently I have a 450w Power supply. How much do i need to upgrade to run this hardware
https://linustechtips.com/topic/815687-need-advice/#findComment-10231342
6 minutes ago, TorubledC said:
yea i figured that but wont the stick cooler do until I cant build up my cash supply, I dont plan on overclocking
The R5 1600 comes with a decent stock cooler that will let you OC a bit without upgrade the cooler, if you want high end overclocks then you should get a different cooler. (I know you said you don't plan to OC but to maximize performance, you should give the R5 1600 a small bump).
You can also sell the parts you have now and get a GTX 1060 6GB instead of the 1050ti, the 1060 6gb would be about $100 more.( but more than double the performance)
PCPartPicker part list: https://pcpartpicker.com/list/JjqpPs
Price breakdown by merchant: https://pcpartpicker.com/list/JjqpPs/by_merchant/
Motherboard: MSI - B350M PRO-VDH Micro ATX AM4 Motherboard  ($74.98 @ SuperBiiz)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($69.99 @ Newegg)
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB Video Card  ($154.98 @ Newegg)
Total: $497.83
Generated by PCPartPicker 2017-08-01 01:04 EDT-0400
https://linustechtips.com/topic/815687-need-advice/#findComment-10231396
Total: $412.86
https://linustechtips.com/topic/815687-need-advice/#findComment-10231431
Total: $497.83
Quick question could i just swap my graphics card to the 1050 and wait until i can afford a new computer, or would my CPU bottleneck its performance?
https://linustechtips.com/topic/815687-need-advice/#findComment-10231433
