mayhems dye should have white
http://www.performance-pcs.com/mayhems-pastel-coolant-1-liter-ice-white.html
Edited by Billy_Mays
got one
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/815534-white-coolant/#findComment-10229686
2 minutes ago, PurpleScythe said:
Are there any NON-PASTEL white coolants, or any way to dye clear coolant white without using pastel colours
They will all be "pastel" type coolants, there are other brands other than Mayhems, such as Primochill that make opaque type fluids, similarly with Thermaltake but their fluids are not recommended by most.
https://linustechtips.com/topic/815534-white-coolant/#findComment-10229687
Pretty sure there isnt. Google kung fu turned up nothing.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/815534-white-coolant/#findComment-10229689
