my system is
Intel Pentium g3220
asrock h81m-vg4
gt 730
4gigs of ram (2x2) ddr3
psu dazumba 380w
now im planning to upgrade my GPU to 1050ti. things that always come into my mind is, will it work optimal ? like the PSU or something ? is the psu enough ? and im also confuse to upgrade my processor and mobo and ram to acquire much more significantly performance. if its not significant i wouldnt....
thats all my question. thankyou
https://linustechtips.com/topic/815275-need-help-on-my-rig/
that cpu def needs an upgrade and more ram
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/815275-need-help-on-my-rig/#findComment-10227208
Just now, Avinsky said:
wht does 'def' means ?
definitely
Peripherals
https://linustechtips.com/topic/815275-need-help-on-my-rig/#findComment-10227218
Just now, Lurick said:
Is that with the 1050Ti included or without?
i have idr 3.000.000 rn, and im planning to upgrade my rig. the first iwanna upgrade ofc is my gpu. and the gtx 1050ti is worth idr 2.350.000. the rest idk wht to buy. or maybe i should save more idk
https://linustechtips.com/topic/815275-need-help-on-my-rig/#findComment-10227235
  • 2 weeks later...
If you wanna get 1050Ti, upgrade the PSU either. G3220 is good I think.
Perhaps save more money either for saving to Skylake/Kabylake. G4560 seems good.
Afraid it will be like Elpiji meledug kalo masih make PSU bawaan Dazumba wkwkwk
Humor me, as you should do.
Daily drivers, below.
Diccbudd PC
AMD Ryzen 5 3600 || ASRock B450M Pro4 R2.0 Motherboard || MSI GeForce GTX 1650 Gaming X 4G || ADATA GAMIXX D35 2 x 8 GB DDR4 3200 MHz RAM || 480 GB Samsung PM981A NVME SSD // 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Deepcool AG300 CPU Cooler || Skyworth H27G30Q 2k 180 Hz Monitor || Logitech M650 Signature Mouse || Nuphy Air75 v2 Keyboard
Samsung Galaxy A34 5G
8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol
Lenovo ThinkPad L390 Yoga
Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD
Personal Server: HP Elitedesk 800 G3 SFF
Intel Core i3-7100 || Hynix 40GB DDR4 || 120GB random SSD || 1TB Toshiba 2.5" HDD
Audio
Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC
https://linustechtips.com/topic/815275-need-help-on-my-rig/#findComment-10271428
Skylake 'upgrade' would be stupid. You clearly have a low budget since your current system isn't even entry level and you're looking to just add an entry level GPU. For a CPU upgrade, youd want to just grab a used i3 or i5 compatible with your current motherboard. As for GPU, a 1050Ti will be fine but you really should upgrade that PSU. It could arguably work, but it's not even remotely safe. You might need a case upgrade, no idea what case you have though.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/815275-need-help-on-my-rig/#findComment-10271528
