i prefer 2 intakes and one exhaust
with 2 exhausts youre promoting air to be sucked in through other small gaps which may not have a dust filter and cause dust build up
with 2 intakes youre promoting air to go out of other small gaps meaning there should be less dust build up overall
https://linustechtips.com/topic/813917-fan-configuration/#findComment-10212393
So should i do 2 intakes in front? or intake in back and front and then exhaust on top?
https://linustechtips.com/topic/813917-fan-configuration/#findComment-10212399
Depends if you have front dust filters. if you have a front dust filter, then definitely 2 in the front one in the rear. if you have no filters, then it probably won't make much difference, but to encourage directional airflow for the benefit of your components, two fans intake in the lowest front part of your case and one exhaust on the rear (or top) would be most ideal.
https://linustechtips.com/topic/813917-fan-configuration/#findComment-10212407
ok with two in front one in back, where should i put the radiator on back or front?
https://linustechtips.com/topic/813917-fan-configuration/#findComment-10212411
4 hours ago, Wobulali said:
single 120 gpu is open air
case has two fan slots on top, two on front, and 1 in the back
well the typical configuration is to exhaust through your AIO, but it doesn't really matter all that much as you're making a tradeoff either way. If you use your AIO as an intake, it will cool your CPU slightly better, but will also slightly heat up other components in your case. if you use it as an exhaust, it will cool your CPU slightly worse (since its using the warmer air in your case for its cooling) but it will slightly lower the temperature of everything else in your case (compared to when it was used as an intake).
https://linustechtips.com/topic/813917-fan-configuration/#findComment-10214878
