Help!! First time build
Go to solution Solved by Herman Mcpootis,
6 minutes ago, Geno296 said:
500$ and yes those parts are the things i only need
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($156.88 @ OutletPC)
Motherboard: ASRock - AB350M-HDV Micro ATX AM4 Motherboard  ($64.99 @ Amazon)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($65.99 @ Newegg)
Other: ASUS PH-GTX1060-3G GeForce GTX 1060 3GB Phoenix Fan Edition VR Ready HDMI DP DVI Graphics Card  ($214.99 @ Amazon)
Total: $502.85
Generated by PCPartPicker 2017-07-27 11:06 EDT-0400
10 minutes ago, Geno296 said:
I didnt buy anything yet but could you help me build a plan that wont hurt my budget thank you...
what is your budget? are those few the only parts you need or do you need a full desktop?
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10207376
You have to provide more information! Budget? What are you using it for (specific and not just "gaming" in general)? One or more displays? At what resolutions?
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10207429
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB Video Card  ($145.99 @ SuperBiiz)
Other: Ryzen 3 1200 ($109.99)
Total: $386.96
Generated by PCPartPicker 2017-07-27 10:52 EDT-0400
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10207434
Um..i think 500$ and i would like to use it in gaming but those are the parts i only need and i am using 1080p
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10207465
Total: $502.85
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10207517
Motherboard: MSI - B350M MORTAR Micro ATX AM4 Motherboard  ($89.33 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2666 Memory  ($65.99 @ Newegg)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB D5 6G Video Card  ($279.98 @ Newegg)
Total: $592.18
Generated by PCPartPicker 2017-07-27 11:08 EDT-0400
I know it's over your budget but you could replace that Ryzen 5 cpu with the new Ryzen 3 1300X (~$130). If you wait a bit memory prices might drop as well again. You could also hunt for a second hand RX580 now that mining hype is waning …
EDIT:
You might even end up with better performance in games with Ryzen 3 1300X due to higher base clock.
Edited by bowrilla
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10207529
Total: $502.85
If i will use that build...can i still upgrade that amd chip into fututre with intel?? If not thats ok...but can you give me the most high quality game it can play?
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10210176
you will have to replace the motherboard if you wanna upgrade it to an Intel CPU. everything should be playable at 1080p, high-ultra should be fine for the 1060.
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10210198
Is the mobo for amd is different from intel...? Can this play most open world games and photo editing like photoshop and corel draw x7? Thanks for the time...appreciate your help.
https://linustechtips.com/topic/813403-help-first-time-build/#findComment-10210246
