Footage from my Hero 5 Session looks corrupted (green all over the place, stuttering) when viewed using VLC via SD card reader on a laptop, but is totally fine when viewed through the Capture app.
Any ideas what the issue could be?
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/813315-gopro-footage-problems/
have you tried using a different sd card?
transfer the file to your laptop/desktop then watch it on there. dont watch it directly from the sd card.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/813315-gopro-footage-problems/#findComment-10206243
I have now bought a new SD card and tried it, but the same thing happens, even with transferring it to the laptop and using VLC instead of WMP.
Edit: I'm starting to think it might be an issue with the laptop's USB ports. They only detect devices sometimes, and have a few other issues. Unfortunately I won't have access to another laptop/PC for another three weeks :/.
https://linustechtips.com/topic/813315-gopro-footage-problems/#findComment-10208140
