Hello i recently bought a new pc and i get no signal on monitor when i plug in my hdmi  it doesn t work even if i plug it in my cpu neither in my gpu ,but when i plug the vga into my cpu slot i get signal in monitor and it s turns on .
i only have two cable a hdmi and vga and right now no possibility to buy another do u guys think its the hmdi cable problem or it s from my pc?
https://linustechtips.com/topic/812397-hdmi-port-won-t-work/
5 minutes ago, M.Yurizaki said:
Try it with another, known working, display if you can. If it still doesn't work, replace the cable with a known working one. If it still doesn't work, it's your PC.
I don t have another monitor but i don t think it s from my monitor because it works with the vga
https://linustechtips.com/topic/812397-hdmi-port-won-t-work/#findComment-10195704
The monitor can have a bad HDMI port.
Alternatively use another HDMI output device.
https://linustechtips.com/topic/812397-hdmi-port-won-t-work/#findComment-10195722
