So in short I cant tell if my problem is my 7700k or my dark rock 3
I have gone through a few things including voltage and reseating the heatsink
I did notice my motherboard has a screw that seems to be in the way of the heatsinks backplate making it stick out a bit
specs 7700k
           msi z270 gaming m3
https://linustechtips.com/topic/812330-7700k-high-temps/
Temps? Kabylake does have major thermal issues (So much so that Intel advises owners not to OC), dont think there is alot you can do other than de-lidding it (Can drops temps up to 30c).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194818
What was the load? If that was Prime95, it seems not reasonable for an air cooler of that size.
While I'm not familiar with the mount of that particular cooler mount, most I've experienced on Intel have 3 holes in a triangle on the back, which should line up with the three screws poking on the backplate. Just be careful not to get it the wrong way around so they conflict.
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194892
13 minutes ago, superidot said:
50s is fine (Albeit warm for that cooler, hot chip as I said though), can probably get away with a moderate overclock as is (Keep it under 90c).
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194897
the top is fine and the screws kind of nestle into foam, the 3rd longer one has gone straight through it and I can see a mark on the plastic where it is butting up into it
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194900
A picture might help here. I can't visualise it.
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194906
that was 5 mins under load at 4.2 ghz, also the high was 80c. If I put on the 4.5 stock boost and went a bit longer id hit 90c
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194911
What is it conflicting on? If you align the cutouts to the protrusions on the base plate the 3rd one of the triangle should fall outside I think.
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194955
I could take a picutre of how it is currently on, the bottom half of the plate dosnt touch the board. the 3 screws that come out of the motherboard are uneven causing the plate to not be flat.
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194966
Can't be sure without seeing it, I think you might just need to remount the back plate rotated 90 degrees so the mobo screws miss the backplate.
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10194972
it did fit much better that way, didnt see anything about that in the manual but i do feel silly. my temps are still getting high but i didnt clean the old paste and apply some new paste yet so i get the feeling this may help. if not im getting a hold of intel. Many thanks
https://linustechtips.com/topic/812330-7700k-high-temps/#findComment-10195085
