5 minutes ago, charlesgray2001 said:
Is Corsair Hydro Series H100i v2 Extreme Performance the best CPU AIO? Is there better ones? Also what is the fail rates?
I think the NZXT one's are slightly better because there based on 140mm instead of 120mm fans.
My life
https://linustechtips.com/topic/812188-aio-corsair/#findComment-10193111
Just now, charlesgray2001 said:
I'm just wondering if they have a higher fail rate because the reviews for NZXT and Corsair AIO's have a good amount of leaks etc.
Seriously though it has a 6 year warranty and that covers damage to your PC too.
My life
https://linustechtips.com/topic/812188-aio-corsair/#findComment-10193127
I have a h100i v2. Quite honestly when you buy an AIO, you're accepting the fact that you're putting something in your system that may or may not leak. IMHO, I just went with Corsair because I like their brand and because I've heard good things and use their fans as well. I haven't been on NZXT's street as much, if not at all but wouldn't say they're a bad brand either, I haven't bought anything from them to justify whether they're bad or good.
"The only thing that matters right now is that you're here, and you're safe."
https://linustechtips.com/topic/812188-aio-corsair/#findComment-10193132
Lets say if it leaks on my 3k system they would cover it all?
The parts that broke yes but it might take a while and I belive there's a Cap on how much they reimburse you.If your this concerned get a Noctua NH-D15 and call it a day.It performs almost identical
My life
https://linustechtips.com/topic/812188-aio-corsair/#findComment-10193144
epoxy that bitch up
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/812188-aio-corsair/#findComment-10193159
I think ima yolo it and get the corsair 100i v2
https://linustechtips.com/topic/812188-aio-corsair/#findComment-10193166
