Hey, I feel my computer has bad air flow since with my H100i my CPU idles around 40-45C and sometimes at 60C and the GPU idles around a similar range
CPU i74790K @4.00GHz
GPU GTX 780 with the DirectCU II cooler from Asus
Case NZXT H440
Front fans are blowing air in.
Rear fan is blowing air out
Radiator fans are pulling air from the top and down
https://linustechtips.com/topic/812102-bad-air-flow/
Case NZXT H440
Also what is your ambient temps?
Your radiator fans blowing air down from top, did I understand correctly?
https://linustechtips.com/topic/812102-bad-air-flow/#findComment-10192124
