All programs showing wrong gpu load except hwmonitor
5 minutes ago, Sam5127 said:
All the programs are showing wrong  gpu load except hwmonitor. I've even tried using DDU to uninstall drivers and reinstall the latest ones.
They all say the same actually
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
wait are you talking about the load, Because there should be load on the GPU as it still has to reander the desktop
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
u see afterburner and gpu-z show 16% all the time whether im playing a game or its idling  only hwmonitor shows the correct gpu load
try reinstalling those two then see if that works, otherwise it is probably a sensor issue where the sensors aren't sending the correct data to GPU-Z and Afterburner
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
but if the sensor's busted wouldnt it send the wrong data to hwmonitor too?
no not saying the sensor is busted but it just the data is possibly getting lost along the way.
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
