My buddy has a Ryzen 1500x and a 1050ti on a gigabyte b350 motherboard. I have a 1060 6gb so I wanted to see how much my cpu (a i3 4350) was affecting gaming, we swapped our gpu's played swapped back and now he is telling me it is loading and windows in perpetually loading. Can someone help me help him. We also put my ssd with a bunch of games in his rig but I had him check iss hdd was top of boot order.
https://linustechtips.com/topic/811225-friends-pc-wont-load/
Probably did not apply thermal paste and fucked his cpu up, be ready to buy a new cpu for your buddy...
https://linustechtips.com/topic/811225-friends-pc-wont-load/#findComment-10182597
try cleaning out and reinstalling drivers in safe mode. if windows 10 fails to boot two times in a row, it should boot into the troubleshooting boot
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/811225-friends-pc-wont-load/#findComment-10184126
if you're just gonna spread vitriol, then go somewhere else.. and if you actually read OP's post in its entirety, you would know they switched GPU's, not a intel and amd cpu with eachother..
Personal Rig Specs
https://linustechtips.com/topic/811225-friends-pc-wont-load/#findComment-10184129
