Hello,
im having issues with coding on arduino, its my first time actually having fun with arduino. So i dont really know what im doing.
What i am trying to do is to make DIY steering wheel and pedals with potentiometers and im getting this error atlibusbdfu.dll
This is code i found on internet.
Potentiometer has limited range of 300° (full turn) so basically  150° in each direction...
Can you maybe guide me towards success
This is the code :
#include "UnoJoy.h"
void setup(){
  setupPins();
  setupUnoJoy();
void loop(){
  // Always be getting fresh data
  dataForController_t controllerData = getControllerData();
  setControllerData(controllerData);
void setupPins(void){
  // Set all the digital pins as inputs
  // with the pull-up enabled, except for the
  // two serial line pins
  for (int i = 2; i <= 12; i++){
    pinMode(i, INPUT);
    digitalWrite(i, HIGH);
  pinMode(A4, INPUT);
  digitalWrite(A4, HIGH);
  pinMode(A5, INPUT);
  digitalWrite(A5, HIGH);
dataForController_t getControllerData(void){
  // Set up a place for our controller data
  //  Use the getBlankDataForController() function, since
  //  just declaring a fresh dataForController_t tends
  //  to get you one filled with junk from other, random
  //  values that were in those memory locations before
  dataForController_t controllerData = getBlankDataForController();
  // Since our buttons are all held high and
  //  pulled low when pressed, we use the "!"
  //  operator to invert the readings from the pins
  controllerData.triangleOn = !digitalRead(2);
  controllerData.circleOn = !digitalRead(3);
  controllerData.squareOn = !digitalRead(4);
  controllerData.crossOn = !digitalRead(5);
  controllerData.dpadUpOn = !digitalRead(6);
  controllerData.dpadDownOn = !digitalRead(7);
  controllerData.dpadLeftOn = !digitalRead(8);
  controllerData.dpadRightOn = !digitalRead(9);
  controllerData.l1On = !digitalRead(10);
  controllerData.r1On = !digitalRead(11);
  controllerData.selectOn = !digitalRead(12);
  controllerData.startOn = !digitalRead(A4);
  controllerData.homeOn = !digitalRead(A5);
  // Set the analog sticks
  //  Since analogRead(pin) returns a 10 bit value,
  //  we need to perform a bit shift operation to
  //  lose the 2 least significant bits and get an
  //  8 bit number that we can use
  controllerData.leftStickX = analogRead(A0) >> 2;
  controllerData.leftStickY = analogRead(A1) >> 2;
  controllerData.rightStickX = analogRead(A2) >> 2;
  controllerData.rightStickY = analogRead(A3) >> 2;
  // And return the data!
  return controllerData;
https://linustechtips.com/topic/810599-issues-with-arduino-nano-coding/
Because someone's going to complain about not using the code tags:
#include "UnoJoy.h"
void setup(){
  setupPins();
  setupUnoJoy();
void loop(){
    pinMode(i, INPUT);
  pinMode(A4, INPUT);
  pinMode(A5, INPUT);
You also didn't say what kind of error you're getting.
Arduino: 1.8.3 (Windows 8.1), Board: "Arduino Nano, ATmega328"
Sketch uses 2924 bytes (9%) of program storage space. Maximum is 30720 bytes.
Global variables use 195 bytes (9%) of dynamic memory, leaving 1853 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x97
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x97
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
This is the error message
