Can some one help. I used to get 60fps on ultra in FO4 and now its limiting me to only 33fps even on low. I tried to fix it by messing with settings in nvidia control panel but nothing has worked.
CPU: Ryzen 5 2600 GPU: MSI RTX 2070 Gaming Z  RAM: 16GB DDR4-3200 MOTHERBOARD: ASUS B450-F Strix
https://linustechtips.com/topic/809913-gtx-1060-frame-cap/
Uninstall the drivers with DDU.
Download the drivers from nvidia and install those.
Repeat test and see if that fixed it.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/809913-gtx-1060-frame-cap/#findComment-10168445
Ah it was out of date drivers that I needed to update via Geforce Experience
https://linustechtips.com/topic/809913-gtx-1060-frame-cap/#findComment-10168479
