I Updated my system to a Ryzen (was using an FX Build) i am wondering what cooler i should try and look into or even hint towards a AIO Cooler. i have a 212 Evo but finding an upgrade kit is super hard to find or the markup is way too expensive for just a simple bracket. should i hold out for a new shipment to transfer it or should i buy a new cooler. Thanks guys i appreciate your guidance and personal experience input
https://linustechtips.com/topic/809894-finding-an-am4-cooler/
Chance that you find AM4 verified cooler will be hard still. Most manufacturers don't have brackets in packages, though its getting better, I'd guess. AM4 is still new platform.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/809894-finding-an-am4-cooler/#findComment-10172739
I got the Noctua NH-U12S SE-AM4, works like a charm. I can't hear it with the case closed and it keeps my CPU temps below 40 for normal browsing and office work, and below 60 for gaming (I didn't bother overclocking yet, I don't have any games my machine couldn't handle out of the box atm). They have two more coolers that come ready for AM4, the NH-D15 SE-AM4 and the NH-L9x65 SE-AM4.
http://noctua.at/am4
https://linustechtips.com/topic/809894-finding-an-am4-cooler/#findComment-10173792
I just installed my NH-D15 to cool my R5 1600 and it never went over 65C after 10min of Aida64 @ 4GHz and 1.45V (60C after an hour @ final stable OC of 3925MHz and 1.3875V). It's overkill for most setups but you will never worry about temps or sound and it's super easy to install.
https://linustechtips.com/topic/809894-finding-an-am4-cooler/#findComment-10198097
