Ethernet problems, unidentified network (Solved)
40 minutes ago, lukesterboy said:Umm ok then. Wow that's alot to take in. Quote me again if I don't respond to something.
You mention about the manufacturer using whatever standard they want. This sparks interest to me and I believe this could have something to do with it... This could totally make sense.
Let me just explain my setup briefly. You have ethernet from router -> to rj45 module with brown and green pairs hooked up in place of the 100mbps setup. So basically where on T56B says use white orange in pin 1 and solid orange in pin 2 I just completely swapped that for the brown pair. I also did the exact same thing in the other end of where the cable runs. So essentially it's acting as the orange cable but actually using the brown. Since the orange is being used for rj11. Green remained in the exact same correct positions. I have a feeling I might have accidently wired it wrong somewhere though. Saying that then the other machines (laptops) shouldn't work if I did. But I will double check tomorrow.
As for the OS i was on win7 pro 64bit when I first had this problem which was tonight and later tonight I installed Windows 10 64bit and tried all the ethernet drivers k previously downloaded as well as the proper supported windows 10 64 bit ones from HP's website.
You mention about a PNY driver issue or something, do you think it's worth me going back to windows 7 when I can to avoid this issue?
-gone-
I have a strong feeling it is the cabling. It has to be. There is no other thing it can be. But it hurts my head thinking that multiple other machines are perfectly fine using the cable.
So i am trying to help you and you have the nerve to say "WOW that's alot to take in" nice real nice......yes it is
and here comes more
. Try to read it in full.
Okay, now you see that 100mbps connector, when a ethernet adapter on a random device is configured to be auto negotiation it will pick it up but if that same ethernet adapter is configured to be full duplex 1000mbps it will automatically drop a connection and you will not have any internet access no matter what you plug/unplug/shout/curse/whatever, the only way you can get a connection is to configure the ethernet adapter to auto negotiation or 100mbps full duplex. this is something to look into. To find out about this you have to open your ehternet properties then click on Configure then on the window that opens, click on Link Spped to see how it is configured under Speed and Duplex.
The wiring just has to have the same wires on wither end so if you go green red then on the other end it has to be the same, this is for straight through, for the love of everything that is good leave crossover alone! just seeing it made me kiss my teeth.
The PHY driver that i mentioned it part of newer drivers and should be run in DOS mode but you really don't need it if you are on Win7, but with WIn10 it can cause issues without it. I had to update my PHY driver for a steady ethernet connection on my Z77 MOBO. The reason why i mentioned it is because this can be a cause but only on Win10.
Reverting to Win7 is an option but only if you have tried every troubleshooting option which should include a fresh Win10 install to see if you get a connection or not.
Also have you tried the desktop in other rooms, if it works in another room then it maybe just the connection at the problem room that is the issue.
