Question regarding cable position
Solved by Mira Yurizaki,
6 minutes ago, xHadrian said:What about what @deXxterlab97 posted then?
What I said still applies. For example, in the eight-pin PCI Express power, three of the pins are 12V, four of the pins are ground, and one is a sense line (which actually is tied to ground). So you can swap around the three 12V lines all you want and it won't change a thing. Likewise you can swap around the four ground lines and it won't change a thing.
So again, you can swap the lines of any cable/pin as long as they're the same color.
