7 hours ago, Max_Settings said:
117 dB SPL/mW
But don't buy HD650s get HD 6XXs, much cheaper for the same thing.
https://www.massdrop.com/buy/massdrop-sennheiser-hd6xx
Quick note on the 6xx - that offer won't last long so hop on it if you can, but they also won't ship till December so you won't be using them until 2018
https://linustechtips.com/topic/808511-headphones-help/#findComment-10154154
Thanks for the information.
I think at that long of a wait, I will again stick to my original plan of buying the HD 650s.
https://linustechtips.com/topic/808511-headphones-help/#findComment-10156711
People who are willing to spend $200 now and then see the product comes in 2018 are probably out of their mind.
https://linustechtips.com/topic/808511-headphones-help/#findComment-10159253
Or they appreciate a good deal and have some patience XD.
I'm assuming its a little bit of both. The demand for those headphones brought on by videos like the one Linus made makes them pretty tough to get a hold of so I don't mind waiting a few months. I usually end up forgetting I bought things on Massdrop since it always takes so long and I end up surprising myself when it eventually shows up haha
https://linustechtips.com/topic/808511-headphones-help/#findComment-10159445
