So recently, my computer started to shut down/restart by itself. I've already changed my Power Supply, but its still giving me this error.
I've also went in the Advanced System Settings and in the Start up and Recovery settings, I've unchecked the automatic restart.
My PC is also not overclocked, I have returned it to default settings and temperatures are remaining cool.
I don't know how else to troubleshoot this :(. Please help.
| CPU:
Intel i7-4790K | MOBO: Asus ROG Maximus 7 Ranger | GPU: Asus STRIX GTX 970 | RAM: Kingstom HyperX 8GB | SSD: Samsung 840 EVO 128GB | HD:  WDC Caviar Black 1TB | PSU: Corsair 650W | Case: NZXT H440
Razer Mamba 2015| Keyboard: Razer Blackwidow Ultimate 2013 | Headset: Steelseries H Wireless | Mousepad: Razer Goliathus | Monitor: Asus PA246Q
https://linustechtips.com/topic/808489-kernel-power-error/
Have you reinstalled Windows?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10152672
Ehh Event ID 42 kernel power errors can be caused by a plethora of different issues.
Driver issues, GPU going out, RAM issues... Are you running the latest version of the video driver(probably try a clean installation of your video drivers)? Is your RAM running at it's advertised speeds or below it? What were you doing when the random crash and restarts are occurring?
EDIT: Forgot to mention, you should also check out your windows power settings. Make sure it's on maximum performance. You can run a RAM stress test as well to get faulty ram out of the way. Do you have more than two audio drivers installed at the same time in device manager? If so try disabling one.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10152679
Not yet, I would like to try that last so that my files won't get deleted.
I have used the Memtest in windows to test the ram, it says its ok. I am running all latest drivers for my GPU, installed using Geforce Experience.
The restarts just happen randomnly, just about anything I do, it just randomnly restarts. And I only have 1 Audio driver installed.
I'll try to do that, Maximum performance thing
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10152732
It's always seems tricky to me whenever I'm dealing with a Kernel Power Error - Event ID 41 error Task(63) issue because it could be hardware related or software related.
So it'll restart if you just leave the computer alone?
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10152744
Well, it restarts even if im doing something. Basically it just restarts randomnly :(
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10152840
Make sure and back up your files first, then they won't get deleted.
Mouse: EVGA X17
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10154221
Yeah, I guess. But, I would like it to be the last resort :(. Does reinstalling windows usually work?
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10154270
If it's an OS problem (sounds like it if it's a kernel error) then yes, it normally fixes those. If it doesn't then you've got a hardware problem.
Mouse: EVGA X17
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10154394
Do I have to reinstall windows through a bootable usb drive? Or the refresh windows here in the settings of win 10 is fine?
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10157948
I'd reinstall it from a USB drive, so you start with a fresh ISO of Win10. And for at the hard drive, so it doesn't make any problems for you.
Mouse: EVGA X17
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10157968
Got it, I'll try that. Thanks! I'll download the media tool at microsoft.
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158007
Do i just pick, Upgrade this PC? or Create installation media?
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158063
Create installation media. Make sure and back up the files on your USB drive to a different PC, since the USB an HDD will get formatted, the USB now, and the HDD when you install.
Mouse: EVGA X17
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158075
Why can't I pick Windows 10 Pro? my desktop currently is Win 10 pro
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158102
It doesn't let you pick that from the dropdown?
Mouse: EVGA X17
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158179
Nope, its Win 10, Win 10 Home Single Language, and Windows 10 N :(
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158215
Strange, it gives me the option to pick Pro whenever I do it. Maybe contact MS support.
Mouse: EVGA X17
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158224
Aight, Got it. Thanks!
| CPU:
https://linustechtips.com/topic/808489-kernel-power-error/#findComment-10158225
