Pc specs for pubg
Go to solution Solved by SquintyG33Rs,
you will be able to do 60FPS but with no effects and reduced foliage (it won't look great). your setup is really good but the game is in early access and and runs very poorly.
Hey guys!
So, apparently I've just built a PC for gaming.
Here are the specs:
CPU: intel G4560 3,50GHz
GPU: Inno 3d gtx 1050 ti 4gb
RAM GEIL Pristine 8GB DDR4 2400MHz
HDD: Seagate 1TB 7200rpm ( yes, no SDD because I was on a tight budget)
PSU: Segotep S7GT 450W
I was wondering if my pc can run player unknown's battleground on at least 60fps at any setting
Please help me, I love this game so much!
Thanks!
https://linustechtips.com/topic/807785-pc-specs-for-pubg/
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10145768
5 minutes ago, datvu4202 said:
Can I turn on effects but like on low?
yeah it doesn't go lower than that. you can't see smoke grenades or other things. it's still perfectly playable
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10145810
16 minutes ago, datvu4202 said:
Have you played it yet?
yeah on a 950
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10145870
5 hours ago, datvu4202 said:
Hey guys!
Here are the specs:
Thanks!
PUBG is having issues with Nvidia graphics cards. I get 30-40 fps
Victor F.
My hobbies include: machining, electronics, radiation, and guns
DESKTOP: CPU: Ryzen 5 3600  Motherboard: Asus ROG B550-I RAM: Corsair Vegenence DDR4-3000 SSD: Samsung 970 Pro GPU: MSI GTX1070 Ti Titanium CASE: NZXT H1
LAPTOP: Apple MacBook Pro i7, 16gb ram, 256gb ssd. (2018 model)
CAMERA: Panasonic Lumix G85
PHONE: iPhone 7
DRONE: Dji Mavic Pro
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146811
Just now, david cassar said:
You sure? Pubg is definitely much worse on amd gpus as far as I know. On my 970 I am able to get a locked 60.
Unless its my ryzen cpu or old driver. I have seen a lot of performace issues with gtx 960's. I have a gtx1060 though.
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146831
I would attribute the performance issues with gtx 960s to how much vram the game uses. The game's textures use a lot of vram lmao.
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146839
But i have GTX1060 and I get bad performace.
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146853
Hmm could be the drivers. Also do note the game is still in pretty piss poor shape in terms of optimization and sometimes I just get random drops under 30 fps for no reason. I recommend lowering the settings to low and see how it performs.
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146860
Its only using 50% of my gpu. Im now getting 40-50
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146884
1 minute ago, david cassar said:
Yeah gpu utilization is a bit of a problem to be fair. My 970 is at most 60% used.
The game just crashed due to some memory error
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10146894
Just now, datvu4202 said:
What about a gtx 950 and I 5 4460 and 8Gb Ram
I can't answer that. The game needs optimization.
Victor F.
PHONE: iPhone 7
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10147700
9 hours ago, datvu4202 said:
I have a brother who also love this game and coincidently, he also have a 950 and core I5 4460 with 8GB of Ram. Can he play too? But on very low setting right? How about 720p
Wow, did it worked??
Hey, let's play together
i'm playing at 1080 just with low settings. virtually no texture (not that they are needed to be playable but they make the game look like something instead of a blur) and i have acceptable FPS. GPU usage pegged at 100% i'm not sure what fps i get because i never looked at the number but it's close enough to 60 constantly that my eyes don't bleed.
that's the graphics side of things but let it be known that i'm on a R7 CPU so millage may vary. i'm not sure how CPU taxing it can be
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/807785-pc-specs-for-pubg/#findComment-10147709
