Hello,
So I got my speakers plugged them in and everything seems to be okay, but after like 1 hour I get that problem with no sound in one speaker and after few minutes it getting back, I tried to changing cabels plugged in and then it just another speaker loosing sound, maybe someone using those speakers and got that problem?
https://linustechtips.com/topic/806978-genius-1800a-problem/
4 minutes ago, Hunlight said:
Hello,
alright, so what speakers do you have lmao. Cant fix a problem if you dont know whats do be possibly broken :)
https://linustechtips.com/topic/806978-genius-1800a-problem/#findComment-10137130
Just now, Hunlight said:
I think name of the thread says it clearly, Genius 1800a , I think its cable problem could it be?
oooh, i see, sorry abt that. They should be wired to your system, no? Make sure there are no loose connections not just at the speakers, byt anywhere in the system :)
https://linustechtips.com/topic/806978-genius-1800a-problem/#findComment-10137147
what u mean wired in the system? there is no drivers for them if u about that I checked official page, also checke all plugged cables all plugged it correctly, and I think that white one 2rca cable is broken or smth, not even sound havent got back for about hour :((
https://linustechtips.com/topic/806978-genius-1800a-problem/#findComment-10137160
