Hi,
I just purchased the Asus Vulcan Pro. Plugging in the headset works fine. Although when trying to use the ROG Spitfire windows attempts to search for drivers (fails) and I can no longer hear anything through the headset. Considering this headset is supposed to be 'driver free' is there anything that could be done to help?
https://linustechtips.com/topic/80574-help-with-this-headset/
returning sounds like the only solution, unless you want to go at it with a soldering iron.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/80574-help-with-this-headset/#findComment-1106566
