i am getting an h320 and the tube fittings are on the sides of the water block so it somewhat blocks the last ram slot and i know you could fit four regular sticks of ram but i don't know if i can fit one with a heat spreader i am getting gkskill ripjaw and and worried if it will fit does anyone know if i can or not in any way.
https://linustechtips.com/topic/80567-h320-problems/
