So i need to find a single slot gpu that will fit in a dell optiplex 990. I want to use nvidia because the drivers are way better. The card will be primary be used for hashing. Any help would be great.
| 3570k @ 4.5 | swiftech h220 ordered after patent issues | EVGA 660ti SC 3gb | 8gb gskill ripjaws | Asus p8z77-v lx | Corsair Ax 750 | Asus Xonar DS | Corsair C70 white | CM quickfire rapid mx browns | G500 |
https://linustechtips.com/topic/80565-gpu-help/
The only singleslot GPUs I can think of are either very very crappy low end GPUs or Quadros / FirePros
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/80565-gpu-help/#findComment-1104683
Only thing in my mind is FirePro W7000. That actually has some horsepower. I also think (don't quote me for this) that AMD card will be better for your plans.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/80565-gpu-help/#findComment-1105842
