I just recently got a Razer Kraken 7.1 Chroma (V1) from a friend, and I have been noticing a ton of issues with the audio in Overwatch. The music on the menu screen especially sounds distorted and crackly, and I can't seem to find a solution anywhere. I have tried reinstalling the Realtek audio drivers and the Razer drivers, and neither have made a difference. I would like to be able to play without this issue, so please help!
PC Specs:
AMD Ryzen 5 2600X, Scythe Fuma 2, EVGA GTX 1070 FTW, 2x16GB G.Skill TridentZ Neo DDR4-3600, WD Black 500GB NVME SSD, 2TB WD Green HDD, ASUS ROG STRIX X570-I GAMING, SilverStone SX700-G, Cooler Master NR200P
Designed for Windows Vista
https://linustechtips.com/topic/805644-overwatch-audio-issues/
Check near the plugs (both sides) for any damage but does this only happen in OW?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/805644-overwatch-audio-issues/#findComment-10122630
The headset and cord are both in great condition, so I doubt it's caused by physical damage. And yes, it only happens in Overwatch. I have tried every other program I own, including Hearthstone, which is another Blizzard game and that had no issues.
PC Specs:
https://linustechtips.com/topic/805644-overwatch-audio-issues/#findComment-10122636
http://www.tomsguide.com/answers/id-3112273/razer-kraken-chroma-headset-working-perfectly-overwatch.html
https://linustechtips.com/topic/805644-overwatch-audio-issues/#findComment-10122659
